mosport
Here's what I did with LSHF-P #0010, previously modded from stock with SX0H LUX-I @ 330mA and a shortened McR-18 reflector... Now packing a FLuPIC v2.2 sandwich driving a P3 WC bin Cree XR-E :naughty:
The original Fraen optic was shortened and combined with A/R coated UCL, approx. 1mm of acrylic material was removed to re-focus. Two corners were dremelled off to disable the bottom positive pad, then attached with AA epoxy. For neatness, I made small washer from Tyvek to sit underneath the optic.
Beam is bleach white, without any warm tint. The Fraen mod produces an intense focussed hotspot within a square shaped die projection (note: little notches are from die wires), surrounded by a small corona. A different pattern than what a reflector produces, but is really growing on me in a retro ARC kinda way. At 2-3m the Fraen's beam is slightly larger than my HDS B42's hotspot, but with less sidespill produced. This is the tradeoff for XR-E spot intensity and throw, pics below are at normal exposure, -1, -2 underexposed (click to enlarge).
Thanks Goldserve for the custom programming! This one has normal v2.2 firmware, except mode 2 was replaced with Max > Hi > Lo > Off > Set Brightness > Set Mode > Repeat since regular modes 2 and 3 have the same sequence. Perfect for when you need maximum brightness on the first click!
:rock:
Derek
:rock:
Derek
