LITEDISORDER
- Joined
- Oct 15, 2006
- Messages
- 79
I put a AW ICR 123 3.7 volt in my P1D CE and on high it shuts off at about 10 seconds. With a 3 volt rechargable this does not happen. Has anyone else had this problem?
LITEDISORDER said:I put a AW ICR 123 3.7 volt in my P1D CE and on high it shuts off at about 10 seconds. With a 3 volt rechargable this does not happen. Has anyone else had this problem?
Not at all. I've had no trouble using a Battery Station protected 3.7 volt cell in mine. And chevrofreak did some run time tests on the P1D CE using a 3.7 volt RCR. I don't know what brand it was, but suspect it was an AW, because he also tested it with a regulated AW cell.Miracle said:does this happens for all rechargable 3.7V batteries on the P1D CE?
:huh2:
Curious_character said:Not at all. I've had no trouble using a Battery Station protected 3.7 volt cell in mine. And chevrofreak did some run time tests on the P1D CE using a 3.7 volt RCR. I don't know what brand it was, but suspect it was an AW, because he also tested it with a regulated AW cell.
c_c
c_c
