gearpig
Hey all, new guy. Love the forum, but a bit overwhelmed with the information. I need a new light. The military issue ones aren't cutting it. I found this forum while searching for something to fit specific needs.
I fly for the USAF. I have an NVG compatible LED microphone liplight, an LED fingerlight, and a minimag with the red/green lenses. (which I recently lost and replaced with another equally marginal light)
I'm getting tired of losing the lenses and switching lights for different needs in the cockpit. Maybe I'm asking for a lot, but here's what I'd like.
- Long battery life (LED based?)
- Small size with both a pocket clip and lanyard
- a button switch, not a twist style on/off
- variable instenstiy
- small low-intensity focused beam 4-6" inches at 1 foot away (for reading charts)
- a larger diameter beam to see a 4' circle at about 30'. (for checking wing leading edge)
- a very high intensity beam for sticking out the window when taxiing at unlit airfields
- The ability to easily switch between white and green (NVG compatible)
- SOS blinking
What do you think? Am I asking for too much? I ordered the Jet C-LE as my first semi-serious non Gov't issue light the other day, but don't want to tape a NVG compat lens/filter to it.
I appreciate the consideration!
- SOS blinking
