nerdgineer
Not everyone likes a twisty; and more importantly, not all twisty switches are equal. There are better ones and worse ones, and I think the differences are worth noting.
There are 3 kinds of twisties: 1) the internal switch type of twisty used in plastic bodied lights (e.g. Princeton Tec twisty lights); 2) the metallic "crush your battery" type twisty (like Arc AAA); and 3) the Civictor style twisty where a spring holds the battery against the + contact and twisting pushes the EDGE of the body against a contact ring on the PCB.
The internal plastic switches have potentially breakable thin metal contacts, etc. which can be a reliabillity problem compared to the solid metal lights (although my PT lights have always worked fine). The Arc type twisty works fine if the threads conduct electricity well; but dirt or excessive grease (most greases are non-conductive) can add resistance to the circuit and create flicker. To me, the Civictor type seems most reliable as the contact points (body edge and PCB) are sealed inside the light, remain clean, and make a very positive contact when activated. The Civictor type also won't crush the battery or rattle.
Two other features also affect twisty function: 1) range of motion of the twisty, i.e. can the twisty head/tail bottom out before the switch closes contact; and 2) the thread engagement of the twisty (how many turns from when the light is on until the head/tail come apart?). More turns means more thread bearing surface to absorb shocks and reduce wear.
Some cheap Chinese 1AA LED lights (5 LED Medea type) had the problem of bottoming out before a good contact was made. The problem could be fixed by grinding off some of the lip of the tail cap, but it was definitely a flaw. Good designs (Civictor, Arc..) either have no ridge in the body guaranteeing no early bottoming out or have appropriate dimensions.
Regarding bearing surface, I counted the number of turns between twisty turning on and light coming apart for some makes. I got:
Cheap Arc AAA clone (the 4 dollar ones) - 2 turns
Medea 1AA 5 LED light - 3 turns
PT Tec 20 - 3 turns to turn on, 4.5 turns to the bottom
Jetbeam CLE - 4.5 turns
Fenix E1 - 5 turns
Fenix L0P - 5 turns
Civictor V1 - 7 turns
So that's it. IMHO, the winner by a wide margin is the Civictor V1: it has the best type of twisty and also the longest bearing surface by far.
Just some thoughts for the twisty fans...
Fenix E1 - 5 turns
Fenix L0P - 5 turns
