I'm about to take apart a Fenix L1P to clean various parts. I need some advice for taking it apart.
The Circuitry + Emitter Block
-What's the best way to unscrew it out of the head? (If it's even possible because it might be glued in, don't wanna mess with it if it's glued in)
-Is there anything i should be concerned about? (Such as trying to not short out the circuit somehow)
-When i screw it back into the head, should i not screw it in too tight?
The Tailcap + Rubber Switch
-What's the best way to unscrew the clicky setup?
Thanks
Thanks
