cree board question
flashburn72
Michigan
Just got a cree p4 from dealsextreme. question is can I put six volts to it?
web site says typical input is 3.7. any help would be great. thank you in advance
mmmflashlights
No, that's too much. You'd need a regulator circuit to drop the voltage down to around 3.5-4V. Some batteries have their voltage sag under a load more than others, but not that much. You could get away with 3 1.5V alkaline cells, not 6 volts though.
Mash
Dx has the regulator board you need, if you intend to drive with volts. There is a range of them, differing in voltage range and drive current. Have a look and see which best fits your needs.
Curious_character
Tiny changes in voltage cause very large changes in current -- that's the nature of semiconductor diodes. Furthermore, as a diode heats up its voltage for a given current drops. That means that if you drive it with a constant voltage, the current can increase dramatically as it heats up.
That's why LEDs are always driven from constant current (or approximately constant current) -- not constant voltage -- sources. You apply the desired current, and let the voltage be what it will be.
c_c
Curious_character
Thanks for the help guy's. I will just keep it around 3-4 volts
A properly designed current regulator should have an open circuit voltage well above the LED voltage. Several volts greater than the nominal LED voltage of about 3.5 volts wouldn't be unusual.
c_c
Curious_character
In a nutshell, what is Fenix doing with their regulator circuit that gets such great performance ?
Fenix uses a current regulator like eveyone else. If they're getting a particularly good combination of run time and total light output, it means that their regulator is more efficient than most. That would be a result of competent design, and perhaps the willingness to spend a few more pennies on the necessary components. It's not hard to design a high efficiency regulator (I've done a couple myself). The challenge is in making it small and cheap.
c_c
