Re: how many lumens does a 2d cell flashlight prov
http://thelightsite.cruxial.com/reviews/eveready_classic2d.htm
Here's a review of a standard 2-D light. It puts out about 1000 lux at it's "hotspot" beam center.
LED light outputs can be found on this chart:
http://thelightsite.cruxial.com/reviews/lux_charts.htm
Remember, though, this is LUX, not Lumens. That means that we are sampling the light at the brightest point in the beam and tells you nothing about how fast the light output drops off as you go further from the beam center or the total light output. Explanation here:
http://thelightsite.cruxial.com/qa.htm#lumens
As you can see, the topic gets very complex very fast. For what you are looking for you would need to measure brightness and dropoff of light from center at various distances. Very few people have the very expensive equipment needed to do this type of measurement.
Even Lumen measurements can be very deceiving. Lets say I have 2 lights that put out 15 lumens total light each. One has a very tight focused beam and one a medium beam. The tightly focused beam will appear brighter even though total light output is the same because all of it's light is concentrated into a small area.
Hope this helps.
