Avatar28
Just wondering how NiMH AAs using an adapter to use them in place of a C or D cell would compare in runtime to using Alkaline C or D cells, specifically in a high drain application like a flashlight.
The specific flashlight I have in mind is the 3W Taskforce with the Luxeon LED. I know that using 2 fresh C alkalines, the light is pretty thoroughly dimmed after a couple of hours. I know a lot of that is also due to the fact that the approx 1 amp current demand kills the alkalines, but by how much? A typical C is rated at, what, 8000 mAh or so and about 20000 for a D cell, right? So what kind of capacity could I reasonably expect from each of these at, say, a 1 to 1.5 amp drain?
On a related topic, can someone please explain the whole "C" thing when talking about currents? Like if you're talking about a 3C current discharge rate, what does that mean?
- AA NiMH rated at 2,500 mAh
- AA Eneloop NiMH rated at 2,000 mAh (I believe someone told me they are happier with high loads than standard NiMH cells?)
- C Alkaline rated at 8,000 mAh
- D Alkaline rated at 20,000 mAh
