Avatar28
I have a couple of L2Ds that I am using for caving. I currently have the mounted to my helmet along with my apex. The problem is that all these lights and the 8 AA batteries really puts a strain on my neck. I would like to find a way to mod the lights to run off some sort of external battery back. The Apex is easy, it's just a matter of extending the cord. The L2Ds I'm no so sure about. Whatever I do can't be permanent, I need to be able to remove them and use them as handheld if needed. The only thing I could think of would be to try to get another compatible body and switch (or even just a body), maybe for an L1D, and attach the leads from the battery pack to a dummy cell installed into it with some sort of silicone to seal the hole around the wire.
