Fallingwater
I bought a hand-crank flashlight with three 5mm LEDs and a small LiIon cell inside. I liked it as all NiMH based hand-crank lights have terribly high self-discharge rates, and a LiIon cell would solve that problem.
I opened it up and found out it was a LIR2032 button cell.
There is, however, suspiciously little circuitry inside:
This made me uneasy, as I know LiIon cells really don't like being charged at more than 4.2V, and that cheap motor working as a generator has a widely variable output.
Then again, I thought maybe there was something under the board for voltage limiting.
As a test I hooked two multimeter leads to the battery terminals, cranked enthusiastically, and sure enough the voltage got to 4.4V!
I'd be surprised if the poor cell in this flashlight lasted more than a few months, maybe even weeks.
I'm taking the LiIon out and swapping in three NiCD rechargeable AAAs.
Now, it's not fair to say that ALL hand-crank lights with LiIon cells in them are like this. Some might have actual charging circuitry built-in. However, unless you are SURE they do, you're probably better off with the old-fashioned NiMH ones.
