I'm referring to the MR-11 size tripple lenses. I stubbled upon this by semi completeing two builds at the same time. I purchased tripple lenses from Future originally intended for a couple of K2 builds. I ended up using one with a tripple Seoul P4 build but I had to hone out three portions at the base to get it to fit down on the Seoul emitters. It turned out that the light output is much smoother from the hot spot to the outer most portion of the ring. I don't know if this is a result of the Seoul die or what. But the light from the K2 sst is just plan aweful and I'm totally dissapointed with the build, to the point where I may change this thing. I'll try to post some beam shots but I have a new camera and I'm not famiar with it's features yet.
On the left,3 K2's at 1000mA. Right, 3 Seouls at 1000mA. Both using the same lense spec'd for the K2/ FL3-N1-LLK2-H.
