Weylan
I am looking to make a fixed lighting light that has one of the Taskled.com CC5W drivers to run 2-3 Cree P4 LEDs.
These are going to be used in a low voltage track light and be a replacement for MRbulbs.
Source voltage is 12V.
So this should be fine to run them since they are 3x = < 14.2V-11.5V?
So this should be fine to run them since they are also 2x = < 14.2V-11.5V.
I can not go 4x because that is more then 12V source. Unless I switch to the MAXflex2.
I am planning to run them at 700ma. So this is a little overdriven, but not too bad if I heat sink them. Now the question is how much heatsinking is practical to extend life?
In realistic terms, what sized Computer heatsink am I going to need to find to use to support 2 LEDs?
In realistic terms, what sized Computer heatsink am I going to need to find to use to support 3 LEDs?
I am talking about computer heatsinks because they are readily available and come in quite a few sizes. Or is just a piece of aluminum U-channel going to be enough? But the LEDs are going to inside a fairly small glass light enclosure.
