Re: 6p lens diameter?
Quick and not so Squeaky Clean
I took a 6P lens out, boiling water to loosen the nitrolon lens retaining ring. And removed the reflector from a Cree Dropin Module.
You are planning on using a Cree behind this right?
Well just know a reflector will give the worst artifact ridden sidespill.
So unscrewed drop-in reflector and used a 3/4'' copper pipe to hold the led part against the body tube. The pipe rests on the lens. Use a pipe flairing tool to get it to rest where the reflector would.
And BAM beamshots!
Sidespill is still present but not bad.
