Modern_Major_General
- Joined
- Jul 27, 2006
- Messages
- 140
Anyone got the new Inova T4 with K2 flip-chip? How ya like it? Is it realy 175 lumens of output? Thanks!
I don't have the T4, but do have the T5 which should be pretty close.
I just barely got it today and haven't used it hardly at all, but did try and do a quick comparison between it, my Fenix T1 with Q5 and Fenix P3DCE with P4.
It seemed to be just as bright as the T1 with slightly more throw to it. Also had a nice warm tint compared to the almost purple tint of the T1 or blue tint of the P3DCE. The P3D didn't hold a candle to either of those lights in throw or overall output either.
Thanks for the input.
I'm trying to choose between the new Inova T4 and the Pelican 7060 LAPD for police duty light to replace my issued SL-20XP (we call them NERF lights because their made of plastic and break surprisingly easily).
There are plenty of differences between the two lights: materials, switch features, emitter types, etc. The only deciding factor that I care about at this point is throw; which one shines more light further than the other? I believe the pelican's smooth and deep reflector is designed for maximum throw, and while the T4 has a textured reflector it does have a very warm tint which should penetrate haze and humidity better than most LED's (sense light at the blue end of the spectrum is diffused by atmosphere more than light at the red end).
Unless manufacture's start rating their lights by candle power again, it's going to be hard to tell which lights have more throw based on lumens alone. If anyone out there happens to have BOTH these lights and can do a side-by-side comparison, please give me a heads up because I would greatly appreciate it! Thanks.
There are a few threads saying the P3D is very impressive in brightness but after reading your post I just wonder ... I got the T5 last week and it's rated at 200 lumens while P3D is at 215 lumens but not good enough to T5? They said Fenix don't over rate their lumens so the T5 is actually about 250 lumens? I don't have any thing to measure the brightness so I'm not sure.
Received my Inova T5 today so can share some observations against my Pelican 7060--hope they help.
T5 beam tint is a lot warmer than 7060-yellowish like an incan
T5 beam is a lot smoother-no rings
7060 has tighter hot spot and throws further but T5 is still no throw slouch
I prefer feel of 7060 in hand (reasonably large hand) as it is slightly heavier and has a thicker body
7060 switch is easier to use esp. momentary
T5 probably is more usable for majority of people with 3 functions and more usable beam pattern.
Regards Stewart
I received mine yesterday. I have to say this is a really great light, from the new switch/UI to the new emitter. The UI is really easy and very intuitive. The tint of the K2 is on the warm side, almost incandescent looking. I have all three T4 models, I upgraded the TIROS model with a Seoul P4 which made it much better than the reflector version. The 2008 model puts it to shame, I'd say 170 lumen is pretty close. I have no regrets getting this light.
Bob
I have an old T3 TIROS and an extra Seoul P4. Is it possible for a newbie to upgrade it? I asked on the "mods" section and general consensus was that it wouldn't fit in the heatsink and the driver would be destroyed by the "freeze pop" method.
