IcantC
- Joined
- Oct 12, 2007
- Messages
- 920
I see many people have started modding lights with a P7, how soon before we see lights with tri or quad P7's?:devil:
I agree, and it exists,I have thought about it for some time and suprised nobody has implemented it! "heatpipes" are the key!It seems the major development in LED's needs to be mounting them on a superconducting heatsinking cylinder or sphere that can move in/out of a focusing reflector.
For multiple P7s, I think one of those bodies with a 10A tail switch (instead of the stock Mag switch) is indicated.Elektrolumens said:A Maglite switch will only handle a Max of 6A. I see them fail if I go much over that. I ran the Stunner at 8A, fried both switches and ruin some batteries. Heat was phenominal.
A single P7 I assume will generate heat, but the mass of the Mag should handle it. Two LEDs would be 1,800 lumens if run at max. But I would only go with a 3D, or 6D cell. For 3D, I think two P7 might be okay, that would probably be 4A at most. For 6D, the LEDs can be wired in pairs, and MAYBE four could be hooked up in there, and sink adequately. That would be as bright as a 3000 lumens yard light. Who needs a narrow beam if you have that? This would pull about 4A to 6A, and would be impressive.
I don't think you want to go more than four P7's in the Mag head, as there may be some overheating issues. That would be the equivalent to 16 SSC P4 LEDs (which would not fit)
As a matter of fact, the inside of the head might need some machining to fit four LEDs, as these LEDs are 12mm diamater.
If you want a MaxFlood, email me, I can make one easy enough. I think it would be fun.
I'm also thinking in terms of a very small flood light, perhaps powered from an 18650. About the size of the DeCree, but a flood, using the P7. It would depend on the need for sinking, how small the head can be. If not the 18650, then perhaps 3C cells. This would also be a fun cool light.
Wayne
