regulator
- Joined
- Jul 22, 2006
- Messages
- 1,221
Since the EX10 and D10 are similar in output and design but use a different battery type, I am curious as to how the following compare in runtime:
1) D10 with AW's 14450 cell and EX10 with AW's RCR123
2) D10 with Energizer (L91?) primary lithium and EX10 with Energizer primary CR123.
I would think they should be close. The EX10 may have a slight advantage with primary cell due to the converter being a little more efficient at the higher voltage. Its possible the D10 may run a bit longer on the 14450 cell due to it being rumored to provide a bit more capacity than a RCR123??????? Should be interesting.
