D
**DONOTDELETE**
Guest
Hello Readers
I am interested in using a colour mixing device as an educational tool in my art classes. The fact that I teach art should already hint at my problem; lack of skill..
I have done quite some research already, and have ordered RGB LED's from superbrightleds.com. I have also roughly figured out how I should wire the thing. HEre's my plan:
The RGB led has 3 channels (only one blue chip), so I will use resistors to limit all three channels to their maximum current. Then I will use 'variable resistors' to limit further the brightness of the channels.
I ran into a couple of things I havent been able to figure out: The spec sheet on superbrightleds.com tells me that the absolute max rating for the LED is 100mW power consumption. But it also lists typical current for each channel at 20mA. If I add three channels at full power together, the total power dissipation is well above 100mW. What am I doing wrong? And if so, what is a lower current value that would give acceptable brightness?
Spec sheet: http://www.superbrightleds.com/TriColor%20LED.htm
Another question concerns how much resistance I need from the variable resistor to completely black out the LED.. At what point does an LED stop giving off light. IS there a wide margin or not?
Any other suggestions are welcome, as are any links that you might have for me. Thank you for your patience,
TTH
TTH
