You will not necessarily get longer runtimes with unprotected cells, but what you won't get is the abrupt shutoff, leaving you in the dark (possibly dangerous, especially for LEO or military; a pain in the *** for most of the rest of us); instead they will start to dim, letting you know a battery change is needed.
The biggest drawback of using unprotected cells is when recharging them; if not handeled properly, they can be
VERY dangerous (I strongly suggest reading up at
BatteryUniversity, as well as doing a search here on CPF for "battery safety"). The second drawback of using unprotected cells is that if you don't change them as soon as you notice them start to dim, they can become too deeply discharged, and rendered useless (will no longer accept a charge).
But if your 139 is a newer one (5V open circuit across terminals, not higher) you can recharge these cells relatively safely (especially after reading up!); just make sure you use your DMM to test them before, during, and after recharging them. Before attampting to recharge them, make sure the resting voltage is at least 2.5V! The 139 is supposed to disallow cells to start recharging if they're below that, but I wouldn't trust it. Next, when one of the 139s indicators turns green, remove that cell and check its voltage; it should be no more than 4.2V, but will probably be less, usually around 4.08~4.15V. When charging two cells at a time, I leave the first one that turns gren out of the charger until the second one does as well, check it, let it rest for about ten minutes, then reinsert both cells to top them off to 4.2V. During this last step, I check both cells frequently until one, the other, or both reach 4.2V; then rock 'n' roll! :thumbsup:
Lastly, I'm not sure, but your Tomahawk might benefit from
AW's new safe chemistry unprotected cells. Lights with high current draw actually DO get longer runtime with these cells. You can use the above link and post a question in that thread abuot your exact light, and if AW can't answer it himself, maybe someone else can, especially if you find out your Tomahawk's curret draw and include it in your question.
Hope this helps, Tony
