I did a search on "flex failure" and got some good info. I took apart my lss, fixed the flex problem, then got to thinking, hmmmm i wonder what kind of o ring is around the optics in this thing. So I removed the little ring that holds the optics in, removed the optics, and lo and behold, there was no o ring! No wonder these things used to leak like seives! I came up with an elegant solution for the leaking problem though, I just cannibalised the o ring out of my mini
m@g light that is seals the lens to the bezel, and it is a perfect fit down in there! It seals the optics, and you can't even see it. Sealing the bezel ring was harder, I didn't have an o ring small enough to fit in the space between the main part of the bezel, and the ring, and I was just going to leave it, then I thought, why not just use one of the rubber bands from my orthodontist? (I have braces) And it fits perfectly! And it is waterproof. /ubbthreads/images/graemlins/grin.gif
P.S. Thanks peter for the offer to replace my light! You are the only person I know who would back up a "second quality" product with a warrantee! /ubbthreads/images/graemlins/thumbsup.gif
