Marduke- By "does not work" I mean the light is off when I click it to the *high* mode. High is the 1st click from the *off* setting. The 2nd click switches the light to low. The light functions as normal on that setting. The 3rd click will turn the light back to the *off* position. The sequence should go as followed: 1st click - High, 2nd click - low, 3rd click -off. The light light currently works as followed: 1st click - nothing, 2nd click - low, 3rd click off.
This torch was purchased from deal extreme it is a MTE SSC P7 C-Bin 900-Lumen 2-Mode LED Flashlight (1*18650) sku# 12623
http://www.dealextreme.com/details.dx/sku.12623
I'm using a single Trustfire 18650 cell to power the torch.
Thanks - Remi
I have almost exactly the same problem with my new MTE P7 - 2 Mode.
The difference in my case is that its the low mode which is not working, high works fine. I have confirmed this by comparing it with another identical light (I ordered 3 of these from DX).
I think what caused it to fail was accidentally inserting the battery in reverse
:shakehead
What I have tried so far:
1. Swap out the tailcaps with one of the working flashlights. Both tailcaps work perfectly in the working light. Problem still there with the faulty light.
2. Opened it up to check whether something looks obviously wrong with the driver - only to find that there is no driver :thinking:
So this is a direct drive setup??
3. Checked the solder joints and they all look OK.
Any other suggestions as to what could be wrong here?
Could someone explain how the high/low modes get set in this direct drive setup?
I see there is a resistor in the tailcap which obviously has something to do with setting the mode. But then why wouldn't swapping out the tailcap fix the problem?
