Hi
Received my K-106 after reading the AA review thread and presumed it would be able to be brighter on high than my Ultrafire A10 both on li-ions and Nimh's / Primaries.
Both are running on Trustfire 14500 (by my measurement at 700mAh before PCB cutoff)
UF A10 has smooth reflector, K-106 has orange peel
I have not been able to do a battery end amp draw test on the Akoray, but can see that the A10 is pulling 1.25A on a hot off the charger cell. Dropping to 1.1 when I checked after 5 mins of running. (this is removing rear and connecting a DMM for 30 secs)
The hotspot on the akoray is noticeably dimmer (by this I mean you can tell the difference, not that the AK is not good when compared) than the A10 and the spill is also noticeably lower in luminicity (that may not be the correct spelling)
I have cleaned the thread, lubed, checked the contacts on the switch and pill and seem to be all Ok.
I am a little dissappointed as I was thinking this would be just as bright, if not brighter than the A10.
I do understand that the driver may be different, lens material will contribute to losses, reflector type, size and depth also play a part, however I am posting this up and the A10 in a single mode high only light is the winner here instead of the Akoray. Outshines a CR2 LIFEPO4 driven P4 WF-606A by a margin that you can see.
I was hoping people who have the same two units can provide their experiences of the two and how they compared.
Also some other things I could check / optimise on the AK that would allow me to confirm I have not lost out on the DX lottery.
I get the fact that this is programmable multi mode with discharge protection which are the features which greatly increases it's appeal, I just feel as if I would have been better off putting the funds into a pot for one of the more "premium" units that have a very high quality driver with excellent regulation.
Also the UF A10 information I could find was sketchy when I googled the CPF site so this would help those looking at the UF, decide how it stacks up for their usage.
Any positive input you guys can provide would be appreciated
