-Erik-
Hello all--
Let me first start off by saying I apologize in advance if this is being posted in the wrong section of the forum.
However if this is the right place I have an issue that I need to work out with my Dereelight. A little back story... When I received the light and put in one fresh battery, the light would not turn on. Knowing that a brand new flashlight could not be defective I made sure everything was tightened good per the instruction guide that came with the light and the light came on. I have had the light for a good two weeks now and have used it periodically without issue.
However today I went to turn it on and the light flickered a few times and then went dead. I figured that the battery's (I am using the extender tube to accommodate 2 battery's) were dead. I replaced the battery's and no luck with the light turning on.
The light will still not turn on no matter the battery combination. I have tried using one battery and two battery's.
I am using Ultrafire 3.7v 2600 MaH battery's if that means anything.
