Just had a quick question for yall. Probly applies to most other electronics as well, but oh well. Would the most efficient use of an LED, be when it was producing light, but little to no heat? I was reading one of my other threads and another member was telling me that if I ran a 900 lumen P7 at 900 lumens output, that only about 1/8 of the energy would leave as light, the other greater part would leave as heat. Well, what if you backed it off some. To say 500 lumens output. You would save battery, (at the cost of lumens output of course) but wouldn't you also gain efficiency cause you were not generating as much heat? Or maybe, you could go even lower and run it at like 300 lumens and generate even less heat. Thoughts? Opinions?
