What driver would be recommended for light applications where you're wanting about 800-1100ma in a 1 or 2 Li-ion application.
I've seen that some of the "cheaper" drivers drop/fluctuate depending on which configuration you're using: 18650 vs 2*16340/RCR. Is there a driver out there I'm missing that might work well.
A manageable width is a plus too...probably no more than 20mm. Height - ehh, whatever.
It can only be a high/off or lo/high/off - nothing else is needed for this mod.
