gcbryan
I have mainly reverse clicky switches on my flashlights.
I do have one Surefire 6P incandescent flashlight. It has a momentary switch.
I hear people mentioning that forward clickies are mainly for single mode lights and reverse clickies are for multi-mode lights.
I'm a bit confused as to what a forward clicky is I guess.
I'm guessing that it's a momentary switch that can click as well to keep the light on when you remove your finger.
If it is used on a multi-mode light does it work this way...
half press as in momentary and light comes on, keep half pressing and you cycle through the modes, when you get to the mode you want you use a full click to lock that mode in.
Is that correct so far?
Then, if you want to go to another mode, you full click to turn the light off and start over with a momentary half press again and cycle through the modes again.
Have I got it correct?
If this is correct then it's still good for multi-modes as it allows for more quickly getting to the selected mode.
I'd like to make sure I understand this.
