Rat6P
- Joined
- Jun 25, 2007
- Messages
- 319
With all the recent performance increases that have become available to us in the realm of LED flashlights, I thought I would share something I have made up.
I'm not sure if this has been done before.
I'm a fan of AA batteries (alkaline, Nimh, lithium) whatever the chemistry, but I also like my CR123 flashlights.
I guess I have a fascination with using whatever you have on hand to do the job you need done.
Where I live AA batteries rule and are easily the most readily available type of cells.
I always buy my CR123's online and have them shipped from the US.
Why just the other day I saw a well known retailer selling clamshell packets of Duracell CR123's(2x) for AU$35. What a joke!!
I know that I can easily scrounge AA's new or used wherever I may be.
This is certainly the same reason why I first purchased a Malkoff M30 to run in a 3 cell surefire on 2AA cells.
Still my favourite combination.
Lately I have been pondering the pros of single cell flashlights.
Mainly for me its the fact that you only have one battery to change out.
Meaning if you are in a certain situation you only need to find one battery to get your torch working again.
For me namely an AA cell is the more likely find.
This said I do enjoy a good pocket rocket and wanted a way to enjoy various chemistries in my flashlight without the need for separate parts that screw on, or spacers that slide in and have to be removed or installed whenever loading a different cell type than was previously in the flashlight.
So the plan for me was to come up with a way of using the following cells in a flashlight and only ever needing that flashlight and not having to carry any other "parts" around with me.
With my first design it is possible to use:
CR123
RCR123
AA(any chemistry)
14500
The second design was changed to allow use of all the above cells plus 17500 and 18500 Li-ion.
CR123
RCR123
AA(any chemistry)
14500
17500
18500
For demonstration and to prove to myself that I could get this idea to work I used my favourite design....the Surefire P series.(though the light in the pics is actually a solarforce)
The parts I used to make the device are what I could find in the garage in the spare parts box etc What you see used in the design is what I could find to make it work...not make it look pretty.
All you need to have is the correct drop in specifically built to operate from say ~0.8v-4.2v.
The design would operate in any 2 x CR123 tube flashlight so long as the electronics are optimized for the target voltage range. And the tube can fit the cells.
For example a Quark AA head on a Quark 2x123 body. I believe also that fenix have certain lego capabilities ..even mixed with Quarks.
Most of you are probably aware of the latest rendition of the Fenix LD10 that puts out around 170 lumens off 1AA cell. Happy days!!!!
Any way here goes. I will mainly try to let the pictures speak..........sorry about the cellphone pics.
In this pic I actually took the picture before I had cut the vinyl pipe down to the correct length. In actual fact it needs to be the same length as a CR123 cell.
Still I think it illustrates the principle just fine. With the pipe cut to length there is still plenty of space for the AA to slide in with ample support. I have actually tinkered with this again since taking the photo's as the spring was a little too long. The whole unit is now the same length as 2 x CR123.
note. this is the AA, CR123, RCR, 14500 compatible device.
The spring setup inside has also now been heat shrink wrapped for electrical reliability.
This following pics show the beginnings of the second protoype and why it was neccessary to shrink wrap the centre spring/piston to ensure electrical isolation and reliability.
The larger spring you can see is a perfect fit for an AA battery and (trust me) a perfect fit inside my SF 6P or other equivalent 2x CR123 lights
In this design the larger spring is actually almost 2XCR123 cells in length. This acheives several things.
1. long enough to firmly hold AA size cells in center of tube
2. ensures a single CR123 cell is held in the optimum postion. ie. the CR123 cell will squash the spring down just enough for a snug fit and not prevent it making a circuit with the center spring.
3. will squash down enough to accomodate 17500 or 18500.(it needs to reduce to 1/2 a CR123 in length.
Once installed in the flashlight the end result is my Surefire 6P or other host with a 0.8-4.2v dropin can now use any of the above cells without adding or changing anything else on the light.
If anyone is interested,
I will try to get some more pics of the finished device up and posted when i have time
CR123
RCR123
AA(any chemistry)
14500
CR123
RCR123
AA(any chemistry)
14500
17500
18500
