Re: One resistor in parallel or a resistor for eac
[ QUOTE ]
CM said:
Doug S,
I don't dispute that assertion. The point I was trying to get across is that if you want to have a more accurate (in my example, it is exact) bias, you would use individual resistors tweaked to that particular LED. But in reality, the Vf does not vary so wildly that this is necessary. You could just use one resistor for the sake of economics. Multiple resistors of identical value is more optimal, a single one is more economical while giving similar results. As engineers, we always have to make design compromises and if it can be done cheaper and obtain similar results, then by gosh that's the way to do it. That's my pragmatism speaking out /ubbthreads/images/graemlins/grin.gif
[/ QUOTE ]
Multiple identical resistors of the same value will give FAR more consistent results than one resistor and all LEDs in parallel.
For example, suppose you have two Luxeon LEDs, one with a Vf of 3.4v, and one with a Vf of 3.6v. You're powering them from 5V. As an example, you choose resistors so that the LEDs are being driven at their rated current at 3.5v. Resistance for each resistor will be 4.286 ohms.
Now, in reality, one LED will be dropping 3.4v and one will be dropping 3.6v. (Plus/minus a few insignificant hundredths since they will not be at their exact rated current.) So the 3.4v LED will be driven at 1.6/4.286 = 373 mA. The 3.6v LED will be driven at 1.4/4.286 = 326 mA. Variance, but not too much.
Now, if you use a single resistor and parallel the LEDs - Let's just take an average of 3.5v. (Most likely it'll be more towards the lower side.) This means a total of 700 mA.
The problem is that at the node with the + side of the two LEDs and one end of the resistor, the voltage is fixed. Given the nonlinear V/I curve of LEDs, the 3.4v LED will likely be quite overdriven at 3.5v, and the 3.6v LED will be quite underdriven at 3.5v. I would not be surprised to see 600 mA+ going through the 3.4v LED and <100 mA through the 3.6v LED - Even a tenth of a volt can make a LARGE difference in the current through an LED.
