Battery Guy
Greetings Everyone
There are a number of choices of batteries for hotwire mods, but when it comes to the AA NiMH variety, it seems to me that only two make sense: Elite 1700s and Eneloops. The Elites have great voltage retention at high loads, and the Eneloops...well, they are just Eneloops.
Over the last few weeks I have been experimenting with several hotwire configurations using both Eneloops and Elite 1700s. I find myself frequently going back to Silverfox's NiMH shoot out data to check out voltage at different discharge currents.
I thought that it might be helpful if I did some additional testing of two of the more popular hotwire NiMH cells, focusing on the discharge rates of interest. I also thought it would be useful to take a closer look at the initial voltage during the first 5 seconds of discharge as this is when instaflashing of the bulb is a possibility without a soft start on the hotwire mod.
My purpose for posting these results is not necessarily to compare the Elite 1700s to the Eneloops, or to say that one is better than the other. Rather, it is to augment Silverfox's test results and provide a reference for those wanting to use these cells in hotwire mods. Anyone with a flashlight that has a regulated power supply that applies a constant power load on the cells would be better off looking at my Ragone Plot for AA cells here.
So below are the results of a large number of constant current discharge tests of both Eneloop and Elite 1700 AA cells.
Here are the cycling conditions for both cells:
charge: 2000 mA to a -delta V of 10 mV (per Eneloop datasheet)
rest: 30 minutes
discharge at specified current to 0.8 V
All of this was done on a Maccor cell cycler. Nickel tabs were spot welded to the end caps of the cells to minimize contact resistance.
The Elite 1700s were discharged from 1A to 10A in 1A increments. The Eneloops were discharged from 1A to 5A in 0.5A increments. (I actually discharged the Elite 1700s in 0.5A increments, but the performance difference is so small with this change that it makes the plots too difficult to read).
I realize that a real hotwire discharge is not constant current. However, as someone pointed out to me when I first started posting to CPF, it is not constant resistance either since the resistance of the filament changes with applied voltage. But I think that constant current is a reasonable representation of how the cells will perform in a hotwire application.
So here are the plots. I scaled the voltage axis from 1.4V to 1V instead of 0.8V in order to expand the axis and better differentiate the discharge curves. Each curve is labelled with a number that represents the discharge current.
The Elite 1700 complete discharge curves:
The Elite 1700 voltage profiles for the first 5 seconds of discharge:
The Eneloop complete discharge curves:
The Eneloop voltage profiles for the first 5 seconds of discharge:
And by request, here are the discharge curves for both Eneloops and Elite 1700s overlaid for 1A-5A discharge:
Also by request, here are the discharge curves for both Eneloops and Elite 1700s overlaid for 6A-10A discharge:
Suggestions for how I can make this data more useful are welcome, as are suggestions for additional testing. For example, I suspect that some of you might want to see higher discharge currents for both the Elite 1700s and the Eneloops. Also, I was thinking that the addition of a high capacity 2500 or 2700 mAh NiMH cell might be useful, but I don't know which is most popular among hotwire modders, or even if hotwire modders use high energy NiMH cells.
I hope you find this this useful. Looking forward to comments.
Cheers,
BG
rest: 30 minutes
Cheers,
BG
