biblefreak
- Joined
- Aug 4, 2003
- Messages
- 25
My first "real" light was an LGI, then a guy at work broke my beloved LGI. Life was not good. Obtained a MAG 2 C, a length of washer hose, a bolt, some 3V CR123's, the NX05 optic from my LGI, a copper pipe cap from the plumbing section of Home Depot as a heatsink, and a nice white LS from King Kong. I used the bolt as a dummy battery, and put a 1watt 2ohm resistor in series to reduce the voltage. The flashlight works beatifully, but my calculations seem to be wrong. The original batteries I had were showing 5.8 volts. I wanted to overdrive the LS at 4.5 volts around .700 milliamps so I used the equation 5.8-4.5= 1.3 / .700 = 1.85ohm's. I put in a 2 ohm 1 watt resistor because that is the closest thing that I had. Now that it is all together I show I am only getting 3.4 volts at .790 milliamps. I put in a fresh set of batteries that metered 6.3 volts brand new, I still get 3.4 volts but now pulling around .870 milliamps!! It seems I should be well up over the 4 volt mark by about .5 or so volts! Any thoughts? Also how is the 30mm optic in a MAG light?
