sethistruckin
- Joined
- Jan 21, 2009
- Messages
- 89
I would like to know if there is an LED that I can swap into my Dorcy Cree XRE 220 Lumen light that would increase lumens. This light is a good thrower already because of the deep smooth reflector, but I am just curious if there are any newer LEDs that would increase the light output.
I would be able to power it with 2 CR123A's with a dummy cell, or 3 CR123A's.
I would lose the recharging capability but frankly that doesn't matter to me. The current battery is a weak 700mah Ni-CD 4.8 volt battery.
I have actually powered the light with 3 CR123As in its current setup for maybe 60 seconds and I saw a significant increase in light. However I am worried that may be too much power for the current LED or driver to handle.
Can anyone chime in and recommend an emitter swap or shed some light on whether or not I would be overpowering the current LED with 3 CR123A's. Thank You. I attached a few pictures.
