I also jumped on the Bulldog sale, after his second price-cut. Got myself a LSH-S.
I can't believe I waited this long. I've had an ARC AAA LE for a bit now, and I've been in-love with it since a fellow CPF'er first recommended it to me.
I *_am_* kicking myself for having waited so long to get an ARC LS, but not very hard of a kick because of Bulldog's excellent deal.
Anyway, to contribute to this on-going thread.
My LSH-S does have quite a bit of farkle. Honestly, though, I could care less, as in this particular instance, I'm "function over form." =) It doesn't impact beam whatsoever, as the FAQs cited.
Color? All I have to say is that it is much whiter than my SureFire KL3 (three), which has a blue tint.
Bright? It's definitely not as bright as my KL3 with either C3 or C2 (my current setup) base, but I'd well wager that the higher output LSH-P will be a match or more, with its tested output at >22 lumens.
Quoted (independent testing, quoted by ARC) at 14-17 lumens output, I can definitely see that the LSH-S model's output should be -- and is -- less than that with my KL3 with C2 (19 lumens, factory quote). No surprises there. My current set of batteries in the KL3 is providing "moon" mode reduced ("moderate") output...and the LSH-S easily beats it out.
With the KL1s being quoted from SureFire at 16 to 17 lumens, I'd suppose that it would be a toss up as to whether or not an LSH-S would be brighter or dimmer -- what all with the variability between independent and factory testing and quotes and all.... But I'm inclined to believe the majority opinion above in that an LSH-P should easily overwhelm the KL1 paired with either a 1 or 2x CR123 combo.
Size? Ever held a KL3/C2/Z48? This ARC is diminutive by comparison. Sure, it's larger than my AAA LE, but just look at the difference in light output.....
I'm a happy camper.
My KL3/C2/Z48 will remain my main general-use LED torch, but the addition of the ARC LS makes for a long overdue alternative in terms of size/storage and convenience (i.e. EDC carry).
Allen
aka DumboRAT
