Z
z_Richwouldnt
Guest
The Solarforce L2x comes only with a reverse clicky switch with external machining that matches the rest of the light. Solarforce forward clicky replacement switches do not match the rest of the L2X as far as appearance is concerned.:shakehead
Upon disassembling the L2X switch and a Solarforce L2-S6 forward clicky switch I found that by swapping actual switch assemblies and some other spacer parts as well as trimming inside the L2X rubber switch cover I was able to assemble a forward clicky in the original L2x switch housing that works great and matches the rest of the light.
