kosPap
I had the idea of modding my Taktikka with an XM-L....
I almost did it, but I decided against it at the end. What kept from it was that I had to permanently modify a part, something I have not have the nerve too yet...
But for the benefit of any interested user here is how it can be done
Here is my headlamp modded with a SSC P4
Here it is with the holder removed.
Here is a look at the holder's underside and the way to mount the new LED....It is Arctic Silver epoxied on a blank SSC star board....I had a look at the Luxeon I datasheet. The LED die is 3.59mm high measured from the star bottom.
Similar calculations of the XM-L setup (assuming that both boards are 1.5mm high) show a height of 3.57mm Very close.
So what one has to do is cut a disc 14mm in diameter from the original LED holder....Easy!
but i did not take the risk.....Maybe some other day when I have the nerve...
Now I am kinda perplexed by output gains.....A T6 XM-L is about 280lumens at 700mA.....
the problem is what bin LuxI I have. The LED removed from my headlamp had this code printed on the back.
RWOHW0439010
0906LXHLHW1D
This means 140deg viewing angle (close to the XM-L's), R-bin=51.7 lumens, WO color and H forward voltage=3.03-3.27V?,
But where there any R-bin LuxI????
RWOHW0439010
0906LXHLHW1D
