turnipfarmer
- Joined
- Mar 10, 2011
- Messages
- 41
I have some Uniross 1300 batteries that are probably about 3-4 years old, I have just purchased a Maha C9000 and also have the B700 charger too.
I ran all my Uniross 1300 batteries through break-in on the C9000 and these are the results.
1 = 1136, 1.42V
2 = 1060, 1.41
3 = 1.73v Imp Test, 770mah, 1.41
4 = 1.55v Imp Test, 1029mah, 1.41
5 = 1.66v Imp Test, 797mah, 1.42
6 = 1.6v Imp Test, 1320mah, 1.43
7 = 1.71v Imp Test, 816mah, 1.43
Is there anything now that I should be doing with these to squeeze more out of them? (apart from number 6 as that one seems ok) or should they be chucked in the bin?
I have read somewhere that I now should do several more break-in cycles on them but setting the break-in capacity of the c9000 before starting it at the capacity I have just recorded, would that be correct?
Also read about the deep discharge method to re-condition old batteries however I don't have a torch with incandescent, just a mini-mag with an LED mod on, would that work?
The C9000 appears to be an awesome charger as well as the B700, I want to try and use them hand in hand, hope I can learn quite a bit from CPF
1 = 1136, 1.42V
2 = 1060, 1.41
