I use a heat gun. It's safer than a torch. Some bezels need a strap wrench, others do not. Some don't even need heating. I've always been able to remove the bezel ring by first heating for 30 seconds with the heat gun, I then try to turn the ring with a piece of rubber strap (mine is vacuum cleaner belt that I cut). If it doesn't come, then heat for another 20-30 seconds and repeat. You should only need to heat it to about 170 degrees. Once the epoxy lets loose, getting it off will be easy. Oh, and do you the vice, just make sure you have your bezel protected well. If you can use nylon jaws. If you don't have them, they are a good investment.
