radu1976
I am tempted to get an RA flashlight as most of the users are happy with them .
Though, I have some things to clarify before . What emitters are they using ?
- 100 and 120 - SSC P4
- 140 OSRAM GDP
- 170 CREE XR-E ?
According to light-reviews.com , both 85 TWISTY and 140 CLICKIE seem to have OSRAMs !?
Is there any connection between a narrow beam/wide one and the emitter used , or that will only be up to the reflector - less or more orange peeled - ?
I am also left in the fog in regards to the REGULATION !
On RA website it's stated that the runtime should be the same for all the versions BUT for the 140 CLICKIE you get 2hrs+ in excellent regulation http://light-reviews.com/ra_clicky/ while for the 85 TWISTIE you get 1hr+ of regulation http://light-reviews.com/ra_twisty/
Should I expect a different runtime for the 120 and 170 lumens versions ? I couldn't find any other graphic for the RA runtime .
So Henry is using different circuit for each version ? It should have been the same graphic as long as the circuit used was the same, isn't it ? And the output difference should be justified only by the efficiency of the L.E.D. used ...
I am tempted by a 120/140 lumens - burst lumens - TACTICAL version with narrow beam , the 170 one will be too expensive for me . Though, I would only look for a version which provides 2hrs on regulation with a primary CR123 - or 1hr with a RCR123 - .
The most convenient priced seems the 120 lumens version as for the 140 one you would have to paied an extra 40$ to get only 20 extra lumens - BURST lumens - as in fact the difference of lumens is only 15 - 100 minus 85 on MAX mode -
I wouldn't go with a light having a runtime graphic similar to HDS 85 TWISTY or NOVATAC 120P - regulation for a short time -
Any input will be welcome .
Thank you !
- 140 OSRAM GDP
- 170 CREE XR-E ?
Thank you !
