I have a Fenix LD15 aa twisty as my EDC right now. Like it alot. Comes on high first and the beam has more focus and throw which I like also.
Have been on the 1st battery since I got it (an Energizer Lithium Primary). Been suing it alot recently in the basement and such and I knew soon it would need a new battery. I wanted to see how much runtime I would get off a battery also so I was using it alot for that reason also . Was in the basemnt yesterday and needed the light . Took out the LD15 which had been running on high just the day before with no issues, and fired it up. HMM output seemed very low. I fugured maybe I went past high and into low. Twist it off and on and no light. Started twisting on and off, on and off etc. Sometimes I would get it to turn on with a weak output and sometimes nothing after multiple twists.
I figured one of 3 things. It crapped out on me, dead battery or dirty threads.
I cleaned the threads and put the battery back in. Same thing still.
Put in a fresh Lithium and it fired right up brite as before with two modes.
So my question to LD15 owners
Does you LD15 behave the same way on a depleted battery? I was hoping for a slower decline in output followed a low output not achieving high but still producing light for a good while in lower and lower levels until I could get a new battery . I wouldnt be left in the dark using Lithiums also instead of a NIMH or something.
I thought Fenix was known for long runtimes and slow declines in out put and very battery efficient? Seems like this light will leave me in the dark when I need it most?
A bit dissappointed about this but I still like the light alot. Maybe a Quark would do better in this area? I dont like the small key ring hole on the quark or it starting on low first though but might deal with it if it does better on depleted cells
