I am sort of new to LED'S and I just have a quick question. I want to power 2 white 5mm LED's (7000mcd, 3.3v to 3.6v max, 25Ma) I have a nine volt battery and I was wondering how to connect the LED's up to the power source. If I wire the LED's parallel then do I add the volts of the lights up or do I still select a resistor for the 3.3 volts? Sorry for such a novice question but thank you for the help.
Andrew
Andrew
