Mattaus
Hi all,
I recently purchased a few of these head lamps from theBay for use when camping. At $10 each (I bid on them at 90c and no one else made a bid :thumbsup they were too good to turn down. They are pretty much perfect for what I want.
I mate of mine did the same and got the chance to use it before me and noted that they chew through their 3xAAA power supply very quickly even on low mode.
Without replacing the LED itself, and trying to keep the closed up device as stock as possible, how could I go about improving the battery life?
Obviously a good set of batteries would help - higher capacity would be best. Maybe a small efficient driver (I would LOVE to get rid of the strobe mode...the most useless/annoying mode in existence). would help a bit. I can't imagine the cheap driver in there now being very efficient.
Not much else really I guess?
Here's a photo of the guts of the light:
As you can see the board is 'unique' to say the least. Also there is a size-able gap between the back of the battery holder and the back of the LED PCB. I reckon you could fit a small driver in there. I'll have to take it apart again to check the actual size.
So anyway...a little random. Guess I should first ask is it even worth it!?
Hope to hear from someone.
Peace.
- Matt
Peace.
- Matt
