pellgarlic
- Joined
- Apr 7, 2011
- Messages
- 59
hi all. hoping to get some feedback on a few specific models, and their relevant drawbacks/strengths. also, if anyone sees issue with any of my assumptions about various aspects, i'd be glad to be corrected if indeed i am wrong =) also, if anyone can suggest a light they think fits my criteria that i haven't listed, that'd be awesome. i realise that some, if not most (or all) of the aspects i raise below will have been discussed elsewhere on the forum, and i have searched and read what i've found, but i'd be interested to hear what people's opinions are of these lights in specific contrast to each other and consolidate it in one place.
what i'm looking for:
- edc (small enough to fit in jeans pocket, awesome if fits in "coin pocket", but pocketable in general is fine - to replace quark mini aa, so not much larger than that, max 3.5" long).
- single cr123 (ambivalent about RCR123 support - only plan to be using primaries. single-cell only, to keep it small, and means less spare batteries need to be carried to "refill").
- very low "low" mode (something in the region of 1 lumen or less - something to help preserve night vision, and to read at night without disturbing my gf).
- current-controlled (as opposed to pwm - afaik this should generally -all other things being equal- translate to better efficiency, i.e. longer runtimes especially on the lower modes).
- decent "max" output (something in the region of 150-250 lumens. the brighter the better, but i don't expect searchlight capability from a single-cell pocketable torch =P and i'd rather sacrifice a bit on highest output for the sake of my other requirements).
- clicky (not bothered if forward or reverse, just not twisty - got a quark mini aa and i love it, but i returned a quark mini 123 cos the mode-skipping was too irritating -lost the "thread lottery" on that one-, and i expect a clicky to have more reliable mode switching than twisty operation).
- no "tactical" ui (i want to be able to readily access all modes, and don't mind having to cycle through all brightnesses, or "disco" modes if they're there. "disco" modes not a deal-breaker, but all other things being equal, i'd choose a light with them, as long as they're fairly well "hidden" in the ui. would prefer to start on low mode).
- can tailstand (so no protruding/tactical switches).
- modestly priced receptacle (excuse the random movie reference, couldn't help it =P but seriously - something in the region of £50-60/$80-100. it'll be a user, not a shelf queen, so not so expensive that i'd cry if i lost it)
models i'm considering, and their strengths weaknesses as i see them (noted lumen ratings taken from manufacturers, so some OTF, some ANSI, some "honest", some "artistic marketing licence" probably =P i know i could get more accurate ratings from a source such as selfbuilt's reviews, but i felt this post was going to be detailed/complicated enough...):
- 4sevens quark 123 (regular, not tactical)
this is the front-runner just now in my mind. seems to tick more boxes than any other. some report "issues" with "pre-flash" (don't know if this would bug me or not, hard to say until i experience it. some say they can live with it, some not). positive: "lego-ability" - if i get the quark 123, i can also acquire an aa body, allowing for flexibility (although the "parts" seem less easy to get in the uk).
-- 3.2" long, low = 0.6 lumens for 29 days =o (current-controlled circuit = v. long run time on this mode), max = 175 lumens for 1 hour, reverse clicky, good ui (won't describe it here - been done well many times already, but briefly: several well-spaced modes), tailstands, ~£50.
- thrunite neutron 1c
this is probably the one i'm next most inclined towards, except for a couple of potential drawbacks, one of which is noted here: http://www.candlepowerforums.com/vb/showthread.php?315743-New-Toys!&p=3656784&viewfull=1#post3656784 - that the battery contact in the head is directly onto the PCB, rather than onto a solid metal "pill", raising concerns about longevity. afaik, no in-field issues have been with this, and my quark mini aa appears at a glance to be the same. not sure if it would actually be an issue or not. positives: switch "lockout" to prevent accidental activation in pocket.
-- 3.5" long (bit bigger than quark, still within acceptable size), low = 0.09 lumens for 100 hours (lower low than quark, but shorter runtime, due to using pwm as opposed to current-control i believe. specs state current-control, but selfbuilt's tests show pwm), max = 255 lumens for somewhere in the region of 1 hour (spec not given, extrapolated from "103 lumens for 2.1 hours" stated spec. smokes quark's highest output, assuming similar lumen scales), reverse clicky, good ui (v. similar to quark's), tailstands, ~£50.
- nitecore ex11.2
this one has an outside chance... slight concern about the constant current draw required for the "piston drive" operation. i've read that there were some problems with the v1 model drawing too much current "at rest", and draining batteries in days, but that the v2 model has addressed that, and touts 3 years "at rest". i just don't like the idea of it using _any_ current when i'm not actually using it... seems like a waste of energy. positives: "shortcuts" to highest and lowest modes (i like the sound of this =) ). "ramping" ui, aka "infinitely variable" - this sounds cool too =).
-- 3" long (shortest of the three - excellent =) ), min = 5 lumens for 80 hours (quite a high "low" compared to the other two, short runtime in comparison to quark implies pwm but i can't find a definite source to back this up), max = 200 lumens for 1 hour (pretty good), "piston drive" switch-mechanism (seems like it would be less likely to "fail" than a clicky switch as less "mechanical"), very appealing ui, tailstands, ~£50.
- nitecore ex11.2
