Wow this looks good.
I also would like to know about this baby for an M1X upgrade.
I do know the led in the M1X is run 2s2p at about 6V.
So I think the voltage would be right.
Not sure if the current would fry it though.
What is the beam from this like.........would it for example be a similar profile beam to an MCE but just brighter/more spill?
May I ask something?
Soem 1A drivers like te "keenan" type can support 2 LEDs in line...Doesn't that mena that hooking up a EW will give 500mA at each die?
The proper drive current for the 6V EZW is 2A. Being that the config is 2s2p, that puts the power to each of the four dies at approximately 3V@1A each. Characteristics are very much like the MCE (especially if you wire the MCE as 2x2). Beam profile was slightly more intense due to higher current and slightly smaller package (smaller dome).
Most current regulating buck-drivers (true DC-DC converters, not resistive regulators like AMC7135 chips) with Vin higher than 6V would work here. I suppose you could parallel two of the kennan-style 1A, 18V in drivers for a perfect fit. (I wish I'd thought of that before the dome disaster.)
I briefly ran the one I had from a 1st generation (large caps) DX 20330 driver, but because of ~1V driver overhead, it could only regulate to 2A drive current if I used two 3.7v batteries and I wanted to use two 3.2V LiFe batteries instead. I tried a 2.8A 8*AMC7135 2-mode regulator, with the LED power-in straight off the switch, and the regulator power in parallel wired to that, but also prefaced by a polarity protection diode to drop input voltage to the driver to below 6V. Something wasn't right though, 'cause it would only pull 1.3A on high. Maybe some of the 7135 chips were damaged, or maybe the emitter Vf was too high. I didn't try direct drive from the 2 LiFe cells, 'cause I didn't want to kill it if I ever forgot later on and loaded two IMR cells.
It was a curiosity satisfied as far as I'm concerned. I like it better than the MC-E, except for with 2 LiFe cells (the 12V version would be better for that, I think), but not nearly as much as the single die XM-L.
