betti154
- Joined
- Jul 7, 2011
- Messages
- 229
Hi,
I thought I'd post the mk1 version of my video light solution.
LED: 6 * XMLS (3S2P)
Driver: TaskLED h6flex
Switch: Apem Prolongated Piezo
Power: 4 * 18650 (4S + PCM)
Dimensions: 60x60x140mm
Construction: Delring body + end cap, alloy head, 6mm acrylic lens.
Charging: It's a 'sealed unit', with charging done via the two port plugs in the rear. They're never removed, but rather are off the shell +/- contacts to the battery that run via a TaskLED Hallsw so that the charging circuit is normally open. It's yet to be built, but the plan is to have a charging disc/plug that aligns two male banana plugs into contact with the port plugs. A magnet (also in the charging disc) triggers the hall switch and the circuit is live. I've tested this successfully by hand, just haven't built the plug that makes it all pretty and houses the magnet.
During a previous thread relating to a piezo/driver issue, it was raised that my bare LED solution was losing too much light due to the lack of reflectors, optics, etc... I cited commercial examples of similar designs, such as the Gates, Light & Motion Solas, Fisheye LED, etc....
Test video with the mk1 solution is below (5 * XMLs @ 3000ma; 2 heads):
One suggestion was a domed lens would be the solution. After some basic research I've deemed this impractical for me, so have ruled it out.
Another comment was that too much light was being lost through the flat lens due to reflections (sideward or inward). To that end, before I assembled the this one I tested the light output both with and without the 6mm acrylic lens. The result was no visual difference in beam width or intensity (hitting a beige wall 4m away). It might be worth noting that with this build I putt some effort in centring the LEDs, versus spreading them around the edges.
The question I'd like pose is whether a DIY reflector that counter sunk each LED would have any value. My thoughts were to make this out aluminium, such that each LED would be exposed through a countersunk and polished hole in a faceplate (hope that makes sense). My theory is the countersunk hole will act as a reflector and push light forward.
I'm also keen to hear any other comments on the design, good or bad as this is the prototype of sorts and I plan to make a batch of them for some cave/wreck projects.
