jerrysimons
- Joined
- Aug 28, 2011
- Messages
- 72
I bought the Quark 2x123 S2 over the R5 because I wanted longer run time (200lm for 2.8hr vs. 230lm for 1.8hr) and was willing to sacrifice a little output to get it. but this was before I started reading about specifics.
Question #1:
If the Quark 123x2 circuitry drives the emitter at 990ma on max for both the R5 and S2 heads why does the S2 emitter have lower output and longer runtime (200lm for 2.8hr) vs the higher output and less runtime of the R5 (230lm for 1.8hr)? From what I read from doing a search on the subject, the S2 emitters are supposed to be brighter?
Which leads to question #2:
2:How did/does 4Sevens measure and post their output/runtime specs? I know they now use ANSI but were both the R5 and S2 models ANSI rated (i.e. max output recorded at 3min)?
2.a: Within ANSI ratings, is it true 4Sevens posts their runtime specs down to %50 rather than down to ANSI %10 (%50 preferred IMO)? It seems this way when comparing charts like selfbuilts to the published 4Sevens runtime specs.
2.b: From what output quantity is the terminal runtime percentage measured from? %10 or %50 of startup output or is it measured from %10/50 of output at ANSI standard 3mins?
Thanks.
Question #1:
Thanks.
