I've had one on my SL-20x for a couple months, here are a few notes:
- Push and hold button to dim, it cycles from one end to the other, then back again and again until you release the button, at which point it holds the last setting.
- You can click the Main Power to reset to full power.
- Smart Feature: With the light off, holding down the button and then pressing the main power button starts it at the lowest setting. Somewhat unwieldy though...
- Double click to start or stop full power flashing. There are no other power flashing options.
- Tail button is "chiclet" style, unsure about durability. Although it is recessed so it shouldn't hit too many things that could hurt it.
- Also worried about extra circuit board when dropped. However, I have never had a problem with the main circuit board after MANY drops onto the concrete.
- Low power problem... There is a point when the battery is low, but not super low, where the light will only function intermittently with the digital tailcap. Hitting the tailcap makes it work, at least for a few minutes, but if you turn it off and on then you have to hit it again. Replacing with the OEM cap makes it work fine. Unfortunately, I don't know where this point is, maybe the last 10-20% of usable life. This may actually be a good thing for battery recharge life. That's why I always carry a Lithium SureFire backup.
Otherwise, this has worked fine so far. It is pretty cool and the flashing light helps get attention from traffic. Kids also like to play with it. But I still always keep the OEM cap nearby...
