My E2DL doesn't seem to be as bright as it used to be. Actually, it's an E2DL bezel on an E1e body. When I push in the clicky switch, it is bright. But when I take my finger off, the light dims or flickers a little bit. I always thought that was just because the battery is too low, but I just took a fresh battery off the charger and got a dim like that on the first turn on. I tested the batteries, they all test between 3.8v-4v, even the one I just pulled out of the light, it measured the highest at 4.2v. So, I don't know if it's the batteries. I have six AW RCR123a Protected 750 mAh batteries, and since I only use one at a time, they've probably only been charged a few dozen times each over the past few years. Could it be that I charge them so infrequently, that they over-drained and got damaged? I could order a new set of batteries, but I'm wondering if it might actually be the light. Any ideas?
Also, the flicker and dim isn't noticeable with the E2DL body on a fresh battery. Only with the 1 cell body. But when I first got this light, I didn't have this issue on one cell.
