I have just completed my collection of Malkoff Wildcats, with Versions V1, V2, and V3.
I took them all out in the yard after dark, and compared them for performance.
I have no beamshots, but I will verbally describe the differences, so that interested people might have at least some idea what to expect from these three different versions of the Wildcat.
They are all awesome in their own ways, and it is hard for me to pick out one that I like best. I'm sure it would be a very personal decision.
All lights were tested with an MD3 body tube with 3 CR123 primary batteries installed, and the heads switched back and forth.
First, the specs:
Wildcat V1
Quad-emitter with 4 XRE-Q5 emitters behind individual optics.
600 Lumens OTF at turn on.
15 degree beam angle.
12 volt max input.
Head diameter 1.8", and about 6.75" long with MD3 body installed.
This light is a true spotlight. The beam looks like a miniature version of the WW2 spotlights or searchlights you see in movies. Or like a Follow-Spot seen in stage and movie lighting.
It is a perfectly round projection beam with almost no spill outside the main beam. The beam is evenly lit all across, with practically no visible hot spot. The entire spot is like a hot spot, but it is big and round. It is basically like what it seems to be, which is essentially 4 Malkoff M60 lights in one head, focused to make one big round beam that's about 8x bigger than the M60 beam. It throws the same as my M60, which is about 150 yards down my road. It has the same lovely soft white tint as my M60 too. It lights up almost all the way across my house from 50 yards away, which means it has about a 25 foot beam-spread at about 50 yards distance.
It is a very powerful spot with throw, having great tint, and is one of the most fun lights that I have. It's hard to describe how much fun it is to throw this round spotlight beam around the yard. It's not really a true "flood" in the normal expected sense of that word, but it is a beam that is unique unto itself. It's like "follow the bouncing ball".
The low setting is about 50 lumens with a slight twist of the head, and gives a similar beam shape at a much lower output for general use and battery savings.
Very useful pair of settings, but no moonlight or very low setting.
I give it a "10" as a belt light, but it's not an EDC.
Wildcat V2
Triple-emitter with 3 XPG-R5 emitters inside individual McLeish reflectors.
750 Lumens at turn on.
12 degree beam angle
9 volt max input.
Same size as V1.
This light is quite a different animal than the V1. It is much more "traditional" in beam, with a definite hot spot in the middle, and a gradual spill out the the sides that is quite large. It really floods out my yard and lights a much wider area than the V1 does by far. The spill gradually reduces in intensity as it gets further from the center. Very seamless in nature, and almost a "fade to black" edge of the beam. Really nice. Tint is a bit whiter and possibly slightly cooler than my V1, but no noticeable blue in it, just a nice crisp white.
This beam, while giving the best flood coverage of all my Wildcats, is a little bit distracting because of the noticeable hot spot in the middle of the beam. It's not as "easy on the eyes" because of that. It becomes less noticeable in hot spot with distance, and when I pointed it at my house from 50 yards away, it lit the whole front of my house up and had extra spill to the sides, which means it had wider than a 32 foot wide beam width at 50 yards. In fact, it probably had over 40 foot beam width before the spill faded out at that 50 yard distance. It's a real good flooder, and I like it alot. It throws the furthest of all the three Wildcats I have too, because of that bright hot spot, and I could get about 175 yards of throw out of it, pointing down my dark road tonight. Not a whole lot more than the others, but I'd give it 25 yards more throw, and I could see a few things further out than I could with the other lights. It's a "flood with throw". If I wanted to stand in the back of the end-zone and light up a whole football field with one light, this would be the one I'd take.
It also has a low setting of about 50-60 lumens with a slight twist of the head.
I give it a "10" as a belt light.
Wildcat V3
Triple-emitter with 3 XPG-R5 behind individual optics, and also with an etched diffuser lens.
900 Lumens at turn on.
9 volt max input.
Same size as V1 and V2.
This is the latest and most powerful version of the Wildcat, and is the current model. It has the least info available out there on the web about it, and I really didn't know what to expect until I got it out into the dark yard. It is sort of a combination of the first two versions. It is not as floody as the V2, and doesn't throw as far as the V2 either. It is sort of like the spotlight size of the V1, but not as defined on the edge. It has a spill that gradually "fades to black" as it gets further from the center, so it lights a wider area than the V1, but not as wide as the V2. It throws about the same as the V1, which is about 150 yards down my dark road.
So, in essence, it has more power than either of the other two Wildcats, but it spreads it out to eliminate any noticeable hot spot, so it's more evenly flooding the area that it lights.
When I pointed it at my house from 50 yards away, it lit up about the same as the V1,which is about 25 foot beam-width at that 50 yard distance. But, it has more spill than the V1, and gradually fades out on the sides, so you see more to the sides with the V3 than the V1, but not as wide as the V2. But you don't get that distracting hot spot that the V2 has, so it's easier on the eyes. And the tint was about like the V2, with a nice crisp white tint, but not soft white like the V1 has.
This is the most "refined" of the three, with the best of all rolled into one. But, it also lacks some of the "fun" of the previous two versions, which gave that super fun "spotlight ball beam" or the massive wide flood with the bright but distracting hot spot. This V3 refines the package and removes the hot spot and widens and fades the spotlight beam to give gradually fading spill outside the main beam, so it gives a very nice controlled flood that is powerful but not eye wearying to use.
And this one has the 50-60 lumen low setting with a slight twist of the head too.
I give it a "10" for a belt light.
So, to sum up.
The V1 is a round evenly-lit spot beam with a defined edge like a ball.
The V2 is a wide flood with a bright hot spot and a little more throw, and a gradually fading spill beam of wide width.
The V3 splits the difference between V1 and V2 with a round spot beam that gradually fades out to the sides, not quite as wide as the V2.
They are all VERY bright lights with great tints and they all share the same size and styling. They all have low settings of around 50-60 lumens with a slight twist of the head.
They are all VERY well regulated and also deal well with the heat, and need no automatic thermal step-downs that other high power lights often need. They all will run on high for more than an hour on 3 primaries in the MD3. They average about one-hour and fifteen minutes on high with that battery setup.
So, how do you pick?
Which one do I like best"
I like them all in their own ways. They are different enough to find things to like about each one. I can't really pick one, but I do have a soft spot in my heart for the V1, because it was my first Wildcat, and there is something about a hand-held spotlight that is too fun for words.
I thought long and hard about the Wildcat before deciding that they would be the focus of my collection, but my real feeling is that the Wildcat might just be the best overall light choice available today. It floods and it throws, and the beams are very useful, the tints are great, and the construction and reliability is the pinnacle of Malkoff quality. If not the very best, it is sure going to be tough to beat. These are some great lights!
First, the specs:
Wildcat V1
12 volt max input.
Wildcat V2
9 volt max input.
Same size as V1.
Wildcat V3
9 volt max input.
So, to sum up.
