Since I got my V10R earlier this week, I've been on the hunt for the perfect single CR123A battery holder. I have a VersaTi pill fob/battery case, but found it's way too heavy. So I set out today to find a plastic one. Went to Big Lots and was checking out the new store to see what they had and just so happened to find this lip balm that looked like the container would be perfect.
I turned up the guts and tossed it in the trash.
Removed the plastic screw inside.
Popped the bottom off and trimmed where the plastic screw was. Used my Dremel to sand down one of the two ribs inside since battery wouldn't quite fit.
All I have left to do is glue the bottom back on. It won't be waterproof, but I would guess fairly water resistant as the cap fits on pretty tight. I might also put a piece of felt in the cap to stop rattle since the interior of the container is about 1/8" longer than the battery.
Best thing of all? $.80 is all it cost and it is a perfect fit.
edit: Mods, I wasn't sure whether to put this here or in the battery forum since it covers any flashlight that takes a single cr123 battery, but it is a battery holder. Please move if you need to.
