Joe Talmadge
Hi folks,
I've been evangalizing the use of headlamps for a number of uses, ever since I discovered how useful they are. I've been using the Aurora for a while, and am especially happy with the following features:
- Very light weight on my head
- Able to direct light via a hinge
- Multiple brightness levels
However, I've found over the past few months that there are a number of uses for which the Aurora's top brightness doesn't cut it for me. I'd like to move to a light that has all of the features above, but whose top brightness is a step up from the Aurora. I realize that probably means more LEDs, and a little more weight, and a little less runtime (if still powered by 3xAAA), but as long as it's just "a little", I'm good to go.
Among the candidates would be something like the Streamlight Septor. The head is on a hinge, 1/3/7 LEDS (I assume Septor on 7 LEDs is much brighter than Aurora on 3 high -- can anyone confirm?), 3AAA so it shouldn't be too much heavier. Is the Septor a good match? Any other candidates? Thanks!
