roadkill1109
- Joined
- Mar 11, 2011
- Messages
- 2,309
M3X Triton
Specs:
LED: Cree XLamp XM-L,
Maximum output: 700Lm(OTF)
Colours available: Black / Gunmetal Grey
Weight: 165.2g/5.83oz (excluding batteries)
Dimension: 43.5mm/1.71"(D) x 176.9mm / 6.96"(L),
43.5mm / 1.71"(D) x 210.9mm / 8.3"(L) with extended tube.
Battery: Uses Lithium 3x CR123A 3.0v (4x CR123A with ext tube),
Rechargeable Li-ion 2x 18650 3.7v or Li-ion 2x 18500 3.7v w/ ext tube
Function: Three brightness levels and strobe mode.
Output and runtime: High Mode 700 Lumens/1.5hours, Medium Mode 120 Lumens/7.5hours,
Low Mode 8 Lumens/90hours, Strobe 700 Lumens/1.5hours.
Sunwayman T40CS
● CREE XM-L LED, with a lifetime of up to 50,000 hours;
● Tactical Tail cap press button switch, slightly depress the side switch for different output modes and standby mode:
Three modes constant output, hidden strobe, SOS (below is the output and runtime of using two 2600mAh 18650 batteries)
Three constant output modes: 788Lumens (2hrs)- 220Lumens (8hrs)- 20Lumens (60hrs)
Strobe: 788 Lumens
SOS: 788 Lumens
● Constant current circuit, constant output
● Effective range of 500 meters
● Uses two 18650 or four CR123A batteries
● Working voltage: 5.5~16.8V
● High quality reflector maintains great throw distance and spread with an ideal beam pattern
● Dimensions: 225mm (length) x 64mm (head diameter) x 25.4mm (tail diameter)
● Weight: 273g(battery excluded)
● Aerospace-grade aluminum alloy
● Military Specification Type III- hard anodized body
● Waterproof, in accordance with IPX-8 standard
● Ultra-clear tempered glass lens resists scratches and impacts
● Tactical forward click switch with momentary on
● Accessories: tactical ring, holster, O-ring, rubber cap
The Olight M3X is the current king of the 2x18650, 4xCR123 format lights. This offering of Sunwayman has nearly identical specs.
Who would win the "King of Throw" crown?
Specs:
Sunwayman T40CS
Strobe: 788 Lumens
SOS: 788 Lumens
