All white 5mm LEDs will have a blue center to them. This is because of the way a "white LED" works. White LEDs are actually blue leds with a green/yellow phosphor. These colors mix together to produce an approximation of white. The balance of tint varies with the thickeness of the phosphor. As a result, the center of the beam is blue and the outside edge of the beam is green/yellow.
With the Premiums, we use the whitest white LEDs we can find. These are the Nichia SB1 bin 5mm type. There will still be some blueish tint to the middle, but compared to a standard LED, the level of blue is noticably less pronounced.
In some designs, the outer circle can be mixed with the center spot to make a whiter beam. This either requires secondary optics or a cluster of 3 or more LEDs. Secondary optics can reduce total output due to losses in the optics but clusters work well. However, clusters have been made obsolete by the new High Dome (lambertian) style LEDs from Lumileds. These LEDs produce a consistant tint across the beam.
But the Lumileds parts are larger and more expensive than a good quality 5mm LED for compact applications. We use both solutions in our line of flashlights.
Peter
